It seems easier to ride than my last Burgman a lot better in the corners and to manoeuver. I have the suspension set at 4 and this is giving Sandy and I a comfy ride, and was contemplating whether to set in a bit softer, it will be one of those trial and error things.
Power wise and can't really comment yet, I have to keep below 4000 RPM for the first 500 miles to run the engine in, but even so we can go along at between 60 - 70 without any problem.
I'm not sure but I don’t think the screen comes up as far as my last Burgman. I am not the tallest and with the screen set in the highest position I can still see over the top quite easily this is not a problem for me as I don't like to look through the screen but would rather look over it, but can report there is very little wind buffeting.
Brakes and other controls are just the same as before easily got at and plain to see, though the heated grips switch still looks as if it as been added at the last moment.
The new dash layout is great and I much prefer this to the older style. It is very pleasing and laid out well. The rev counter and speedo are easy to read as are the fuel and temp gauges with their segmented style. You can select between having the temp display or mpg displayed, I had the mpg displayed most of the time and can say that we were getting 57 mpg most of the time.
There is a noticeable reduction with the storage under the seat you can still get two full face helmets in and a few other bits, but the front helmet has to be positioned in a way so when closing the seat down it doesn't press on the top of the helmet, but saying that once you know this we didn't have any difficulties with it.
Apparently the bike is narrower than the previous model. I had no difficulties placing my feet on the ground when stopped and as I said I’m not the tallest.
So all in all we are very pleased with the new Burgman we had a couple of good trips out and the bike preformed extremely well. I do miss the intercom and radio so this will be one of my first accessories to get.
R
