part failier
- phantom309
- Current Ride: nc750sa
part failier
riding up the motorway on friday,an the sym started a little wiggle, so pulled off at next junction an pulled over ,tyre going flat ,checked it but nothing ,luckily someone pulled over an offered a air pump to get me bit further as motor bike shop only half mile away..it worked..shop had a look an said that the right angle tyre valve had burst....
so glad it was a slow leak , an that close to somewhere that could fix it...so thanks to sutton motorcycles ...
- JohnR93
Re: part failier
It is handy having sideways valve stems but any 'over enthusiastic' air pressure checks or fillings can put undue strain on the stem.
- andyscooter
Re: part failier
sutton bromsgrove
if id known id have come and helped
- burgerman
Re: part failier
Just had exactly the same thing on the Wing! Nearly home Sunday, things got a bit squirrely. I thought the front end was playing up, so I rang the my local spannerman, told me to take it round. Dropped Mrs B off at home, set off to the bike shop nice and steady,(1 mile away), halfway there it tried to chuck me off!phantom309 wrote:riding up the motorway on friday,an the sym started a little wiggle, so pulled off at next junction an pulled over ,tyre going flat ,checked it but nothing ,luckily someone pulled over an offered a air pump to get me bit further as motor bike shop only half mile away..it worked..shop had a look an said that the right angle tyre valve had burst....so glad it was a slow leak , an that close to somewhere that could fix it...so thanks to sutton motorcycles ...
newscooter
Re: part failier
The Honda SWing rim will take the Ariete metal 'sideways' valve , they are pretty robust and lightweight alloy.
- burgerman
Re: part failier
Thanks for that, I'll bear it in mind. Is there a UK stockist, 'cos all the ones I found on Google were in the States?
newscooter
Re: part failier
Got mine from e-bay and fitted them at the too often tyre change !!
Re: part failier
you could always just have a straight valve fitted, then use a 90 degree or 45 degree extension to your tyre inflator, they do them to either just stay there or detach and keep just for tyre inflation, under a fiver for twonewscooter wrote:Got mine from e-bay and fitted them at the too often tyre change !!
http://www.ebay.co.uk/itm/PAIR-MOTORCYC ... 337c92201e" onclick="window.open(this.href);return false;
- mottza
Re: part failier
Never leave a extension on. They can cause rapid deflation as I found out!
Re: part failier
are we still talking about valvesmottza wrote:Never leave a extension on. They can cause rapid deflation as I found out!
