oil
john
Current Ride: yamaha xmax 125
oil
Post by john »
Hi got a yamaha xmax sport 125 ,needs oils changed manual recomends yamalube but cant get it so what oil should i use instead in engine and gears .
Re: oil
john wrote:Hi got a yamaha xmax sport 125 ,needs oils changed manual recomends yamalube but cant get it so what oil should i use instead in engine and gears .
motor oil for your scoot is 10w/40 so a good grade of this is the same as the yam-lube just not there brand :D think you need about 1.4ltrs so need to buy 2x i ltr which will cost you around £16...i tend to use Smith and allen website for my oil you can get 5ltrs for the same money take a look here http://www.smithandallan.com/prodpage.aspx?id=1868" onclick="window.open(this.href);return false;
not sure about the gear oil as you got a wet clutch i think, will have to wait for the tmax lads to chip in :D 8-)
Re: oil
Why the TMax lads? He has an XMax!
But it is 10/40 and it does have a wet clutch... and it needs to meet or exceed the requirements of JASO MA, it should be a mineral oil and not semi-sythetic or fully sythetic.
In my TMax I use Castrol Semi-Syth though and it meets JASO MA. But intend to switch to Silkolene as my nearest bike mechanic had some on special so I bought 10 litres...
john
Re: oil
Post by john »
Ok cheers guys ,thanks for your help there .
john
Re: oil
Post by john »
So is it 10w40 mineral oil for gears too?
Re: oil
not sure about the gear oil... likely not it should be much lighter.
Re: oil
Probably something like 80W 90 but it should have all this information in your user manual if it came with one?
EDIT: If not then you can look here http://www.yamaha-motor.eu/uk/services/ ... index.aspx" onclick="window.open(this.href);return false;
EDIT: EDIT: I was totally wrong in the user manual is says for final transmission Yamalube 10W 40 or SAE 10W 30 - 0.25 litres
Re: oil
Hi and welcome aboard.
Re: oil
Funkycowie wrote:Probably something like 80W 90 but it should have all this information in your user manual if it came with one?
yer sorry Funky, its just i was not sure on wet clutches :D but i kmew the tmax has wet clutch also :kiss:
Re: oil
all I did was google the answers :D
