Xmax 400
Re: Xmax 400
I've got an XMax400... Had the older style '09 XMax250 before...
Dunno how they compare with the Majestys - same engine / and filters from what i can tell etc etc- might of modded the tune / cams / variator set up...
MPG is about 65ish - so same-ish as the Majesty... bit more upright in its riding position, not really feet forward... Majesty look more touring / Burgman-esque... XMax is Cheaper - non adjustable levers, no parking brake...
Suppose its like comparing an Estate to a Coupe or Hatchback, with similar underpinnings
Re: Xmax 400
I believe the Majesty 400 and Xmax 400 have totally different frames, the Xmax is steel tubes and the Majesty is cast aluminium.
Re: Xmax 400
I know I'm a cynic, but to me the Xmax 400 looks exactly like the Maj400, except with a Tmax styled front end on....
stollie
- Current Ride: YP250
Re: Xmax 400
Hey xmaxpaul how does your xmax 400 perform as i know they are not as big storage under seat but thought they had virtually the same motor as majesty 400. Seating position i know is sit up but have you done long ride on your xmax and what is comfort on arse like.
