DCT - Honda's Dual Clutch Transmission
anonstarter
Current Ride: Pending
Post by anonstarter »
There was a brilliant article in Gizmag (that Poldark found) about the NM4 Vultus that really helped to explain Honda's DCT and how it worked! I haven't ridden a DCT bike - but now I want to! :D
"Honda's Dual Clutch Transmission
Honda has been seeking to make motorcycling simpler for a long time. It produced automatic versions of its 400 cc twin and 750 cc four cylinder road machines for a brief period in the late 1970s and I spent a week on the CB750A at that time and loved it. With an powerband restacked for low-range torque and two-speed Hondamatic gear-changing, it was simplicity personified – twist-and-go and enjoy the ride.
Even then, the trends Honda was watching in the United States car market suggested that motorcycles would one day be automatic, as automatic transmissions were taking over from stick-shifts in cars. Humans want simplicity it seems and by 1976 when Honda launched its automatic motorcycles, two thirds of new car sales were fitted with an automatic transmission.
The current percentage of new car sales in America with automatic transmissions is 92.5 percent. The staunchly traditional motorcycle marketplace did not however, feel the same way about the idea of an automatic motorcycle in the 1970s and the Honda CB750A only garnered a few thousand sales. It was shelved and it was another three decades before the Honda DN-01 emerged with another automatic. The DN-01's "Human Friendly Transmission" was a CVT, but regardless of what mechanisms it used to do its job, it was an automatic.
The Dual Clutch Transmission is different though. It uses two clutches: one for first, third and fifth gears, the other for second, fourth and sixth, with the mainshaft for both clutches concentric, and each independently controlled by its own electro-hydraulic circuit. When a gear change occurs, the system pre-selects the target gear using the clutch not currently in use. The first clutch is then electronically disengaged as, simultaneously, the second clutch engages.
Honda spent a lot of money and time developing its own DCT. It's the only motorcycle currently in production that uses a DCT, though quite a few manufacturers use dual clutch transmissions in their performance cars. Numerous models from Ferrari, Audi and Porsche, plus supercars such as the Bugatti Veyron, Lamborghini Huracan, McLaren MP4-12C, Mercedes SLS AMG, BMW M3, Nissan GT-R, Mitsubishi Lancer Evolution X use dual clutch transmissions and Lotus has just applied for a patent for a simplified DCT. With a list of DCT devotees of such quality, Honda's efforts in developing the only motorcycle DCT in existence seem more than justified. A DCT does it faster and more efficiently and smoother. Q.E.D.
Remarkably, the DCT fitted to the Vultus is already Honda's second generation motorcycle DCT, the first being fitted to the 2009 VFR1200F.
The Honda DCT offers three modes of gear changing - automatic twist-and-go in D and S mode...
The Honda DCT offers three modes of gear changing - automatic twist-and-go in D and S mode, plus a trigger-operated computer-game-style manual MT mode - similar to the paddle gear-changes on a Formula One car and quite different to the foot-pedal operated sequential gearbox of a traditional motorcycle. In MT mode, the gears are shifted manually using the left index finger to shift up and the thumb to shift down
Traditional motorcycle enthusiasts love to pedal a manual gearbox, loading up the gear shift lever and flicking the throttle off momentarily for a fast gear change under acceleration. The irony is that novices will be able to change gears faster and smoother on the NM4 because the co-ordination of swapping cogs efficiently is done with technology, not with human clumsiness. Put two riders of equal weight, reflexes and co-ordination on two otherwise identical bikes, one with a manual gearbox and one with DCT, and the rider of the DCT bike will be faster over a quarter mile. Similarly, when hurtling into a corner and downshifting under brakes, enthusiasts love the challenge of getting it right by blipping the throttle and matching the revs to avoid the rear wheel chirping, as there's nothing quite like mastering a big motorcycle to make you feel king of the universe. Beginners will be able to achieve the same feeling and results without the same degree of riding expertise on the NM4 – another reason enthusiasts will hate it.
The DCT delivers a quick, smooth, consistent, seamless gear change conducted by a computer that is better than any human can orchestrate with a clutch, throttle and shift-pedal ... every time, no brainpower required. As the transmission transfers drive from one gear to the next with infinitesimal interruption of the power to the rear wheel, there is no gear change shock, and pitching of the machine is minimized, making the change feel direct as well as smooth.
The NM4 does not have a clutch lever or shift pedal. The Honda DCT offers three modes of gear changing – automatic twist-and-go in D and S mode, plus a trigger-operated computer-game-style manual MT mode – similar to the paddle gear-changes on a Formula One car and quite different to the foot-pedal operated sequential gearbox of a traditional motorcycle.
In MT mode, the gears are shifted manually using the left index finger to shift up and the thumb to shift down. This can even be employed to use engine braking to stabilize the bike on the entry into a corner. As it has two clutches, the NM4's power is delivered to the rear wheel without a break, and downshifts are seamless.
The digital dash of the NM4 changes colour depending on the drive mode selected, with subt...
The digital dash of the NM4 changes colour depending on the drive mode selected, with subtle colour changes from Neutral (white) through D (blue) to S (pink), ultimately to MT (red). The rider can choose one colour from five other tonal ranges of each colour - 25 individual colours altogether.
Automatic D mode is ideal for city riding, and offers the best fuel economy. Automatic S mode is sportier and the ECU lets the engine rev higher before shifting up and shifts down sooner when decelerating for extra engine braking. In either D or S mode, the DCT offers manual intervention – the rider simply selects the required gear using the up and down shift triggers on the left handlebar. It's not immediate, but soon after you've told it you want to go up or down a gear, it will shift seamlessly into that gear. Thanks to engine mapping and a well-programmed ECU, the DCT is designed to seamlessly revert back to automatic mode when it decides the excitement is over, using a number of parameters (throttle opening, vehicle speed and gear position) to make that decision. If you're a purist or a control freak, the Vultus will piss you off big time.
Furthermore, in D mode, the DCT system detects variations in rider input typical to certain environments, from busy urban streets to mountain switchbacks, and adapts its gear change schedule accordingly to create an extra level of riding compatibility. Motorcycling newbies raised on game systems will love these adaptive features, traditionalists will not."
Read the full article here: http://www.gizmag.com/honda-vultus-nm4- ... 3-90798141" onclick="window.open(this.href);return false;
Re: DCT - Honda's Dual Clutch Transmission
So that was the reconstituted sales blurb, here's how it works: http://world.honda.com/motorcycle-pictu ... CT/detail/" onclick="window.open(this.href);return false;
tha-mask
Current Ride: Honda DN-01
Post by tha-mask »
and here is the HFT one http://world.honda.com/motorcycle-picturebook/HFT/" onclick="window.open(this.href);return false;
Gilera 125VX, Piaggio X9 250SL, Burgman 400 K2, BMW C1 200, T-Max MK1, Gilera Nexus 500 MK1, Aprilia Mana 850, Burgman 650 Exec K8, Honda DN-01
At the end of the day DCT is a bloody marvellous system which ultimately gives us more choice in the market place. I appreciate though it's not to everyone's taste..
I'm now DCT Intreaged!
I've got a week off next week, gonna visit 21st Moto in Swanley and see if they will let me out on a DCT equipped bike...
Is DCT gonna be the norm, replacing CVT for anything say over 400cc?
XMax400Paul wrote:I'm now DCT Intreaged!
Probably not, but I can see it becoming more common on bikes as it increasingly becomes acceptable among motorcycle and scoot riders.
irev
Current Ride: AN400
Post by irev »
As it becomes the norm in racing, all the small penis brigade (sorry, `sportbike riders`) will have to have it, alongside their Akridpileshit exhaust and tit-an-I-am kneesliders,
If you convinced those dipshits that a chocolate cock on the cylinder head improved their lap times around the ring road, they'd all smother themselves in melted Cadburys.
About the same herded sheep response as the `leg dangle` in racing. Absolutely NO benefit whatsoever, but a psychological barrier designed to put the wind up the competition. I can think of several racers of yesteryear who, if you did that to them, they'd use as the opportunity to dive up the inside and break your femur in two...
As for DCT, it's more expensive than a conventional clutch and gear, but similar enough that, as volumes increase and unit costs fall, it might become common but probably not the norm. But take-up will be defined by the number of new riders, NOT this generation of neanderthals on two wheels. The conservatism in the motorcycle market is truly stunning for its stupidity, as it's held up development for nearly fifty years. At the moment I see synergies with the previous iteration of ABS, where a really good rider could beat the systems of the day. but as the ABS generations mutated we reached the point we are at today where no rider can beat ABS under almost any circumstance.
When the electrickery of DCT matures into a `thinking` mode beyond where it sits now, then we will have a gearchange system that allows for improved performance in every aspect of riding - speed, acceleration, fuel efficiency and engine management. It also needs to be used in the smaller end of the market, in real maxi-scooters and they need to get away from bloody silly chain drive.
About two years should do it, assuming DCT does actually sell. I hold little enthusiasm for the industry to promote it.
Post by Bluebottle »
irev wrote:As it becomes the norm in racing...
Have MotoGP lifted the ban on DCT?
irev
Current Ride: AN400
Post by irev »
In Vicky speak: No, but yes, but no: I don't think DCT is outlawed, it's simply impractical in this application as it creates additioal weight and bulk.
Yamaha are using the `seamless shift` gearbox, the internals of which are a closely guarded secret, but they admit that the system allows for shortened shifting time, increased stability, with the motorcycle less 'upset' by gear changes.
The shorter shifts are achieved by engaging the next gear before the present gear has been disengaged, so somehow they have the means to swap cogs without de-clutching.
Honda have had their own variant for the past two seasons - evidenced by the stability under braking, the absence of kicking or popping on downshifts, and by the fact that neither Marquez not Pedrosa seems to use the clutch lever after the start.
http://www.zeroshift.com/assets/pdf/Aus ... 0May11.pdf" onclick="window.open(this.href);return false;
is the best technical article on seamless shifts - and again it follows the derivative format rather than being a revolutionary design. On the face of it, the Zeroshift design seems to pee on DCT, HFT and CVT. If it is their design in the Honda, then the performance benefit is unassailable. But if Honda are pinning their hopes on their own design ("there's gold in them thar patent hills") then they need to sell it to learners and newbies, and the spurtbike brigade alike, or else the volume will not come - The Viffer 12 being the archetypal case in point.
What I do find peculiar is why it hasn't appeared on the GoldWing. Maybe the next Wing will bypass DCT and go Zeroshift? In which case DCT is merely transitional tech, and will have a very short shelf life.
irev wrote: I don't think DCT is outlawed...
I think it is, or at least it was in my day:
"Regulation 2.4.2. Twin clutch transmission systems (DSG) are not permitted."
But as we know, that is the trouble with holding racing up as the pinnacle of what bikes should be.
