http://www.halfords.com/webapp/wcs/stor ... TMAMQ#tab4" onclick="window.open(this.href);return false;
Slick 50 Engine Treatment - alternative uses?
- larryblag
- Current Ride: Honda NC750S
You couldn't make it up...
Previous bikes, many and varied. Last: KAWASAKI J300 SE
Re: Slick 50 Engine Treatment - alternative uses?
silly sausageslarryblag wrote:You couldn't make it up...![]()
- larryblag
Thanks Mike heed takenmichaelphillips wrote:silly sausageslarryblag wrote:You couldn't make it up...![]()
http://www.halfords.com/webapp/wcs/stor ... TMAMQ#tab4" onclick="window.open(this.href);return false;![]()
i would not use slick 50 in your small quantity of oil in the j300
contains P.T.F.E. which can cause blockages on air filter paths and airways the oil is transported on
as the pathways are small in the engine , i would not advise it
Although sausages in the above example might still stick
truelarryblag wrote:Thanks Mike heed takenmichaelphillips wrote:silly sausageslarryblag wrote:You couldn't make it up...![]()
£8 delivered, stick 8ml in the gearbox and the rest 92ml in the engine oil, works wonders smooth and quite engine
http://www.ebay.co.uk/itm/281254948014? ... 1439.l2649" onclick="window.open(this.href);return false;
then use this concentrated cleaner ... 20ml on a full tank lasts ages £5 delivered http://www.ebay.co.uk/itm/320892220460? ... 1439.l2649" onclick="window.open(this.href);return false;
- Steve_D
- Current Ride: Honda SH300i
In 1987, I bought my first brand new vehicle - a Bedford Rascal van to use for my mobile car repair business. I planned on keeping it for a long time so the first thing I did when buying it was to put Slick 50 in the gearbox and rear axle - it was a relatively new product on the market around that time. Co-incidence or not, I had to have all the gearbox bearings replaced under warranty before it had done 200 miles. I didn't tell the main dealer of course! I drained the axle, put fresh oil back in it and have never used Slick 50 since.
Honda SH300i
Honda SH300i
- johnp
- Current Ride: The Wife
You do wonder about some peoples mentality
Ferret
The zx1 products and the active8 products can be safely used in your scoot unlike slick 50, however we used to use slick 50 on bearing surfaces etc many many moons ago when rebuilding race engines . I would however make sure the motor that you wish to add theses types of additives too has done a few miles and is bedded in well before using . I only use the zx1 but in everything now great product .
