Can anyone tell me if it's possible for me to turn the 'Change Oil' warning light off on my 2009 400? I do my own servicing/oil changes and changed the oil about 300 miles ago.
Cheers Chris
Turning off 'Change Oil' light
Chilly
- Current Ride: Burgman 400
- bornagainbiker
Re: Turning off 'Change Oil' light
With Ignition Off, press and hold the Select button for 3 seconds whilst turning on the Ignition. The Oil Change display will blink 3 times then go off. Page 2-14 of the manual.
Riding a Suzuki Burgman 650 L1 and a Piaggio Fly 125 3v
gingernuts
Changed the engine oil last night and tried the advice for turning the "change oil" legend off but no good!
Am i missing something? (2006 650 Burgman)
Alex
Alex
- bornagainbiker
Yes, the above procedure is for the Burgman 400.gingernuts wrote:Changed the engine oil last night and tried the advice for turning the "change oil" legend off but no good!
Alex
Try this for your 650
1) Turn off ignition.
2) Hold both the SELECT and RESET buttons in.
3) Turn ON ignition
4) After 2 seconds the indicator to change oil should extinguish.
gingernuts
Ooops!
Cheers bornagainbiker I will give that a try : )
THANK YOU : ) IT WORKED
no onboard tools and no user manual : (
