sym 400
charles1976
sym 400
Been offered 12 plate with 13k Mike's max sym 400 for £2500....just after peoples thoughts & opinions....
Re: sym 400
Having seen almost new ones with much lower mileages advertised for a few hundred pounds more it sounds a bit expensive tbh.
At 13,000 miles it will be needing a new belt if it hasn't had one already.
Theres a newer one in white with less mileage which has been on Biketrader for months, it would probably go for even less than £2500
No ABS is a major negative.
charles1976
Re: sym 400
Is it the private one?...called number no reply..
ALY
- Current Ride: KAWASAKI W800
Re: sym 400
There is a 62 plate on Gumtree with 6500 miles and extras,white for £2500 ono,have a look.
May be the same one gn2 mentioned.
charles1976
Re: sym 400
Spoke to startrite bikes of Leeds..new belt around 220 fitted...and needs changing at 12k! .....looked at gumtree but too far to travel if it turns out to be no good etc.....
Re: sym 400
Thats a lot for a relatively simple scoot! eg Tmax belt around £100, and approx an hours labour to fitcharles1976 wrote:Spoke to startrite bikes of Leeds..new belt around 220 fitted...and needs changing at 12k! .....looked at gumtree but too far to travel if it turns out to be no good etc.....
charles1976
Re: sym 400
Things always seem to cost a fortune for me!
Re: sym 400
If you have set your heart on this one, get the belt and pop down to Welsh wales one day and i will fit it for you...good days ride and job done with coffee and cake to followcharles1976 wrote:Spoke to startrite bikes of Leeds..new belt around 220 fitted...and needs changing at 12k! .....looked at gumtree but too far to travel if it turns out to be no good etc.....
Lyn.
ALY
Re: sym 400
You realise with an offer like that you will be inundated, best to buy more cake in.
charles1976
Re: sym 400
Thanks for the offer...Wales..
