Hi everybody,
I'm developing a new vehicle and had to measure the whole swing of the Tmax 530 ABS 2013.
Now I,m done and I have the parts for sale.
Price is Yamaha dealer price - so I make no money on those.
I just want the parts to be used.
Additional will be the freight cost.
Here the list:
Amount Yamaha# name
1x 93332 00010 Brg,Cyl-Cal 74g Ky
1x 15B17 52400 Holder
1x 59C17 65100 Pulley, Belt - SOLD
1x 59C22 10M00 Rear Arm Assy 1
1x 59C22 10N01 Rear Arm Assy 2
1x 59C22 19X00 Cover
1x 59C22 46500 Holder
1x 93306 205B5 Bearing
1x 1J722 14300 Nut, Pivot Shaft
1x 90201 22018 Washer, Plate
1x 90201 25020 Washer, Plate
3x 91312 08020 Bolt, Socket
1x 93102 25017 Oil Seal (25x40x5-101)
3x 95817 10025 Bolt, Flange(3gd)
2x 95817 10090 Bolt, Flange
1x 95822 06012 Bolt, Flange
2x 99530 14016 Pin, Dowel
1x 15B22 14100 Shaft, Pivot
1x 4B522 24300 Washer 1
1x 59C22 14F00 Damper 1
1x 59C25 87A00 Holder, Brake Hose
2x 59C46 15300 Collar, Guide
1x 90101 16003 Bolt
3x 90110 06163 Bolt, Hexagon Socket Head
1x 90387 16019 Collar
1x 90387 17011 Collar
1x 93106 40013 Oil Seal
1x 93210 50553 O-Ring (22f)
1x 93306 07809 Bearing
1x 93306 20662 Bearing - SOLD
1x 93332 00086 Bearing
3x 95812 10100 Bolt, Flange(4my)
2x 98507 05050 Screw, Pan Head
1x 99009 62500 Circlip(Mf1)
Hello and sale of rear swing parts for a Tmax530 ABS 2013
Re: Hello and sale of rear swing parts for a Tmax530 ABS 201
Welcome
Can you say what your project is?
sirgomez
That will be an electric, single seater, three wheeler for commuting.
max speed 90km/h.
300 Kg weight.
17KW constant - 25+ KW for 5 seconds should give a good kick.
One wheel in the rear with a swing solution inspired by the Tmax 530.
max speed 90km/h.
300 Kg weight.
I would have thought a lighter scooter than the TMax would be more suitable or even a lighter motorbike.
Sounds exciting
I'm a big fan of that kind of shenanigans
sirgomez
Maybe it would work with a lighter bike - But I want to be on the safe side - bikes are most designed to have the driving force in wheel direction with the tilting - "more wheelers" have added a lot of side force that the bearings need to handle.
And maybe I want to update my batteries to 100V and use the 35KW peak performance one day
So now I only use the rear brake assy (great with included handbrake), the rear damper (for low point of gravity), the rear rim, belt and sprocket.
A preview attached
A preview attached
