Should I panic?
- smeghead
Should I panic?
Just popped the reg number of my new Silverwing into an insurance comparison site and it shows as a Honda Hornet. Should I panic or is it just a cock up?
Re: Should I panic?
I would query it with your insurer just in case because you might not be insured to ride...
- Current Ride: Forza 125
Re: Should I panic?
No need to panic.
Just a cock-up with the entry to the insurance database.
Just enter make and model manually and you'll be fine.
This happened to a few PCX owners, it came up as an S-wing.
- smeghead
Re: Should I panic?
Thanks GN2 I'll call the dealer shortly ans just query it.
Re: Should I panic?
Don't do that unless you have half an hour or more to killsmeghead wrote:Thanks GN2 I'll call the dealer shortly ans just query it.
Go back on the site and select your make/model manually first, see what happens.
- smeghead
Re: Should I panic?
I've spoken to the dealer. As it is a franchised Honda dealer they were very efficient, the guy checked the plate on the bike and then emailed me the HPI check. It all looks OK so I must assume the insurers have keyed in the wrong details.
OnlineMrGrumpy
Re: Should I panic?
It does happen...my Tmax was coming up as a Virago 535 on one insurer's system! Just make sure all the docs say its what it is.
Normsthename
Re: Should I panic?
A couple of years ago I owned a small Microcar.
That used to show up as a 125cc Scooter
1975 Honda GL1000 Goldwing
- StephenC
- Current Ride: Kymco DT X360
Re: Should I panic?
You can check any vehicle's basic details on the http://www.gov.uk" onclick="window.open(this.href);return false; website. Go to the site and search for vehicle check. Enter the reg number and the manufacturer and it will bring up the info.
Can is not the same as Should
