Over 15lt fil up ?
SOLO
Current Ride: Piaggio X8 125
Over 15lt fil up ?
Post by SOLO »
Hi
I filled my bike uptoday, my X9 tank is 15lt but i manage to get into my tank 15.88lt, how is that possible ? i did not spill any ither it was to brim.
Solo West Yorkshire Leeds! Wacht out for killer taxi drivers!
Re: Over 15lt fil up ?
Two things spring to mind.
1: quoted tank capacity is often less than they can actually take.
2: fuel pumps not always super accurate.
It's the pump which is out
Ralph
Post by Ralph »
If it is the pump thats out report it, fuel is to expensive without paying for more than you are getting.
Pumps are checked by weights and measures and I doubt it Asda would purposely do this.
Ralph
Nr Fleetwood
KEEFYBEE
Current Ride: Zontes ZT 125-M
Post by KEEFYBEE »
I'd be careful letting your fuel level get to such a low point. Aprilia quote 15.5 litres including reserve for the SR Max but rarely do I let it get that far into reserve (around 13 litre mark). Its probably more likely that you pick contaminants up if you let it run down that far, and then they can get into your engine and cause problems. That is unless you fill up with the occasional tank of fuel with the cleaning additives.
Ferrit
Current Ride: MP3 400ie
Post by Ferrit »
Fuel tank levels do not include filler pipes and are quoted only in round numbers rather than say 15.5l. Careful though running your tank so low, at the bottom you will start to pick up crap and sediment you do not want to get into an injector system.
2013 Mp3 500sport
2007 MP3 400ie
A less than Civil Servant
Herts & Beds SERV
It could be the fuel pump - I once had a Tesco pump that was happily saying that fuel was being dispensed (and money clocked up), but nothing was going in the tank!
I know there may be some extra capacity in fuel lines etc and the tank may not be exactly 15l, but 0.8l extra is too much for that. Piaggio would have claimed a 16L tank in that case! Remember the fanfare when the mk3 Tmax tank had a whole extra one litre capacity compared to the mk2....
Deleted User 796
Post by Deleted User 796 »
As it's your bike solo I'd say there's probably a hole in your tank! ;)
Also daft using a mobile in a petrol station or any electrical device.
Thats rubbish how many people switch phones off when filling up .
