Hello all,
This really seems like a very informed group! At your convenience, I was wondering if anyone out there knows of a proven way to remove these scratches simply caused by shoes/sneakers.
Thanks.
BMW C600 scratches in black plastic step thru area
Ferret
Re: BMW C600 scratches in black plastic step thru area
Ok there are various ways of repair to these types of plastics . Firstly if they are only minor applying heat gentley to the area can remove the finer marks . The other option for textured plastics is to sand down the area if the damage is deep ,then clean and spray on some textured plastic repair paint . The cans normally have 2 nozzles to allow for a coarse or fine texture . You can also use some silly putty to make a mould to replicate your texture and then press this onto the heated repair area to make the repair.
- kishan
polishing the marked areas should remove it, is it rubber marks or is it where the paint work has been scratched through the lacquer?
