My 400 Burgman wont start!!
burger uk
- Current Ride: Big burger aka the armchair
My burgman wont start!! it was running rich and lumpy and not ticking over, now it wont start at all, it has a spark and fuel to the plug, anyone had a similar problem? it could be one of the many sensors at fault??
Alexis050891
- Current Ride: 1999 Burgman 400
Re: My 400 Burgman wont start!!
Sounds like mixture to me if it was running bad before. What colour is the spark plug? That will give you a clue as to whether it is too much or too little fuel.
Waspie
- Current Ride: Silverwing
It may help if you state wether it's pre 2003 or post 2003 as the F1 system and all its sensors will come into play in trying to consider what is wrong.
2009 Silverwing
2004 Burgman 400
2004 Burgman 400
burger uk
its a 2005 model fuel injected, i was running mega rich with a slight black smoke, the plug is black.
- paula4u
- Current Ride: Suzuki Burgman 400AN K8
I am not very technical but this explained a bit..
http://www.spark-plugs.co.uk/pages/tech ... gnosis.htm" onclick="window.open(this.href);return false;
ooops another Burgman AN400 K8 again and...
YAMAHA VIRAGO DX535 AND XV250
Suzuki SV650S
Skoda Octavia is for lazy driving
Past Bikes: Honda S-Wing 125, Suzuki Burgman 400AN K3, Yamaha YBR125ED, Burgman AN400 K8
Suzuki SV650S
- paula4u
Have you got the maintenance manual for it? Dont forget look for help at
http://www.burgmanusa.com" onclick="window.open(this.href);return false;
Suzuki SV650S
Suzuki SV650S
Alexis050891
Ok it's rich. I'd check your air filter first too see if it's clogged and check the air line to the carb for blockages/squashed tubes.
burger uk
air filter is new, pipes to throttle body look fine, not getting any fuel injection warning lights on on the dash, may try to jump the dealer mode plug to see if it throws any fault code on the odometer display. other thanthat, its a visit to the dealers!!
- J J
- Current Ride: Burgman ANz 650 k9
Without the "FI" light coming on to show a problem there wont be any fault codes to read.
It's not a case of a pre K7 400 Burger eating it's oil via the crankcase breather/ Air Filter is it?
JJ
JJ
Currently on an ANz 650 K9 Burgman Exec in Metallic Silver
Previous bikes include: AN 400 K4, X9250sl, X9125, Pug Speedfight XRace, NVT175 Rambler, Triumph T140, Triumph T90, Triumph T20, Velo LE, James Captain, Honda 175
burger uk
I'll try it, i tried the dealer jumper and as you rightfully say no fault codes, although i did manage to programme in a new key to the ecu!!! something dealers charge a fair bit for and it took minutes!!. i will see if i can locate the crank case breather filter.
