Hello everyone!
Hello everyone!
Hello everyone, As a 'silver scooterist' I've never done this before so I'm a little nervous and excited! I've just changed from motorbikes to a scooter, 2016 SH Mode 300i and I love it. The only problem is I find putting both feet down a tad of a stretch - I know I could put one down, as per motorbike, but, somehow, it feels odd! That is probably just me. Do you know if it is possible to lower the suspension on the new SHMode?
- Greyerbeard
Re: Hello everyone!
It's a bit of a scooter problem, unfortunately - the seats may be low, but the footboards are wide!
Usually they're so well balanced that tiptoes will do, but that doesn't help when trying to move it around...boots with the thickest soles possible can help.
If the rear suspension's adjustable, is it on its lowest preload?
1964 Matchless G3
1989 Honda C90
1998 Honda CB250 Nighthawk
2025 Honda ADV 350
1989 Honda C90
2025 Honda ADV 350
- StephenC
- Current Ride: Kymco DT X360
Re: Hello everyone!
Hi and welcome. Kawasaki saw this as an issue with the Kymco Downtown so when they adopted it as the J300 they put cut-outs in the footboards to help.
Obviously this is absolutely no use to you (apologies) so on a more practical note, I think it is usually possible to remove padding from the seat and so gain a little from there.
Can is not the same as Should
Re: Hello everyone!
Hi, thank you for the interest. Wide footboards make short legs a little shorter! I've begun to wear my motorcycle boots which do have thicker soles and heels. My partner adjusted the suspension to its lowest preload, but, as you say, moving it can be a pain.
Do you know if it's possible to buy a replacement shock kit which would allow the suspension to be lowered by a further inch or two?
Re: Hello everyone!
Stephen, my bottom likes the padding so I think I'll keep the seat intact, but thank you for the thought
- StephenC
Re: Hello everyone!
Well then you'll just have to swap the Honda for a J300. Obviously, everyone who has a Sh300 should anyway...Elizabeth wrote:Stephen, my bottom likes the padding so I think I'll keep the seat intact, but thank you for the thought
- kishan
Re: Hello everyone!
welcome
Re: Hello everyone!
Hi. The problem of buying rear shocks that are shorter is you have to check under the seat area and to the rear air box inner side as lowering could cause issues with clearance. So advise checking first
- horobags
Re: Hello everyone!
hi and welcome elizabeth. I would leave the shocks alone and speak to-
http://www.motorcycleseatworks.co.uk/
he can reduce the seat height without removing any comfort, good prices and exellent skill, Ive used him several times.
Re: Hello everyone!
What he said.
Welcome aboard
Welcome aboard
