Hello from Farnborough
voyager-a
Post by voyager-a »
I have just got a 2012 Burgman 400.
Turn the key and all that happens is it clicks.
It won't start. The battery has been changed as well as the starter relay
Any suggestions please.
Re: Hello from Farnborough
Post by Bluebottle »
Welcome aboard.
Start with the easy stuff - is the side stand up and the cut-out switch set to run?
kishan
Post by kishan »
welcome
Scootypuff snr
Post by Scootypuff snr »
Welcome.
You have covered the two main culprits but depending on usage batteries soon flatten through lack of use. (Did you use a recognised battery or eBay bargain)
Have you tested the new battery voltage
Is the wiring loom standard or has extras been added (alarms)
Around 2011/12 Suzuki had issues with the right switch gear (affected GSX 750s as I recall & my intruder 800)
Otherwise as bluebottle states start with those items
stevew
Current Ride: Maxsym 400i
Post by stevew »
Farnborough Kent ???
Orpington, UK
2014-Honda Wave 110i
2013-Sym Maxsym 400i
voyager-a
Post by voyager-a »
stevew wrote:Farnborough Kent ???
No, Hampshire
Regards Rod
voyager-a
Post by voyager-a »
Scootypuff snr wrote:Welcome.
I bought a Rob Hunter Battery, and charged it up before installing on the bike.
voyager-a
Post by voyager-a »
Bluebottle wrote:Welcome aboard.
No it's not the side stand.
Regards Rod
earth cable to motor gave trouble on some 400,s. the cure was to fit another earth from the frame to the motor..
