Out today on my '99 burger 400 and the speedometer suddenly stopped working
I believe its electric (as opposed to mechanical) so where do I start looking for a failed part. Is there a fuse?
All help appreciated
Ta
Speedo fail
- Current Ride: Yamaha 900 diversion
- Current Ride: Burgman AN400
Re: Speedo fail
Main failure is at the sensor mounted at the front wheel. The central rotor broke on mine. I'm fairly certain there is no fuse.
- Current Ride: Maxsym 600i
Re: Speedo fail
This happened on the 06 Burgman I used to have. Must be a bit of a weak point.
Re: Speedo fail
Yep, busted rotor. Thanks gentlemen
Now fixed
Now fixed
