Nicely packed away the fittings for attaching the givi sliding screen to the scooter when I moved house.......I've looked everywhere and can't find them ( it's just the bottom four bolts and what ever else is needed).
If anybody has dealings with this screen can you tell me what the fittings are please......looks like there might be some spacers?
I know I should remember what there was but it was months ago I took it off. I've looked on the net for pics, but no luck....also contacted a few sellers and givi, but I'm not holding my breathe.
Thanks
Wuyang
Honda Sh300 sliding screen help
- Current Ride: Sh300
- Steve_D
- Current Ride: Honda SH300i
Re: Honda Sh300 sliding screen help
From memory, it’s just 4 x 6mm bolts. The 'spacers' are all part of the bracket that the screen bolts to.
Honda SH300i
Honda SH300i
Hi Steve......found 4 x 6mm long Allen key bolts......the bracket that the bolts go through has no spacers included on this just a flat plate of metal the bolts go through.....ill give them a try, but it would seem there's nothing for the plates to mate up against other than the plastics.Steve_D wrote:From memory, it’s just 4 x 6mm bolts. The 'spacers' are all part of the bracket that the screen bolts to.
I'll give it a try and get back.
Thanks
You require Givi fitting kit A1100A pictured here
https://www.mandp.co.uk/a1100a-givi-scr ... 0i-11.html
- Current Ride: T-max mk6
Gosh! I've seen simpler mechano kits!!!
[quote="Symcity"]You require Givi fitting kit A1100A pictured here
Cheers......had another go, the Allen key bolts I have are no good, fit but allow the brackets in the pic to touch the paintwork.
Givi have got back to me and say I need part number....307AKITR, this is what attatched the bottom bracket to underneath the light fairing.....looks like I'm missing the four bolts and possibly spacers to keep it from rubbing the bodywork.
- Steve_D
Ah. I’m going on my one which is a 2009 model. I take it yours is a much later model?Wuyang wrote:Hi Steve......found 4 x 6mm long Allen key bolts......the bracket that the bolts go through has no spacers included on this just a flat plate of metal the bolts go through.....ill give them a try, but it would seem there's nothing for the plates to mate up against other than the plastics.Steve_D wrote:From memory, it’s just 4 x 6mm bolts. The 'spacers' are all part of the bracket that the screen bolts to.
Thanks
Honda SH300i
Honda SH300i
It's the 2008 model......the bracket in the pic above that attatched to the bike looks the same.Steve_D wrote:Ah. I’m going on my one which is a 2009 model. I take it yours is a much later model?Wuyang wrote:Hi Steve......found 4 x 6mm long Allen key bolts......the bracket that the bolts go through has no spacers included on this just a flat plate of metal the bolts go through.....ill give them a try, but it would seem there's nothing for the plates to mate up against other than the plastics.Steve_D wrote:From memory, it’s just 4 x 6mm bolts. The 'spacers' are all part of the bracket that the screen bolts to.
Thanks
See if this works,,,,,not the best pic...I have removed the sliding bit,
<a target="_blank" href="httpws://imageshack.com/i/pngwSHlGj"><img src="http://imagizer.imageshack.us/v2/150x10 ... gwSHlG.jpg" border="0"></a>
- Steve_D
Well I’ve got a a Givi airflow AF308 and it’s nothing like that picture above.
It’s like this:
https://goo.gl/images/SrsUQY
I might have some spare brackets/spacers in work on an old broken screen if it is.
It’s like this:
Honda SH300i
Honda SH300i
