So how does the gearbox work on the 650?
I understand that you can manually select gears or use it in auto like my Honda NC750x DCT. but the burgy has a variatior too doesn’t it?
Does it have a two clutch system AND a CVT system?
I’m confused! But then it doesn’t take much these days!
Gearbox on 650
- Current Ride: Honda NC750X+ Peugeot Metropol
Gearbox on 650
Some days you’re the lamppost. Some days you’re the dog.
Re: Gearbox on 650
No its a variator with preset positions instead of roller weights uses a motor to change postion and gearing .
- Current Ride: X-ADV
Re: Gearbox on 650
Also has overdrive sixth gear....but it only works ( it does go into 6th on auto but that 6th is NOT overdrive ) you have to be in Manual mode.
So if you are on the motorway in auto 6th you change to manual and you will notice the bike drops to 5th, you press the up gear button to go into O/D.
And O/D will show on the clocks.
Re: Gearbox on 650
Thanks.bustupbiker wrote: Wed Sep 26, 2018 11:29 am Also has overdrive sixth gear....but it only works ( it does go into 6th on auto but that 6th is NOT overdrive ) you have to be in Manual mode.
Is auto 6th the same ratio as o/d. Although if it is there wouldn’t be any point in having both.
Does o/d give better mpg?
Really appreciate the info guys.
Re: Gearbox on 650
As Lyn said have to go to manual to get OD .I think that only started on exec 07 onwards
Re: Gearbox on 650
Yes you only have to look at the rev counter to see the revs drop..
- Current Ride: 2017 650 Exec
Re: Gearbox on 650
I have a 2017 exec. Yes, when at speed and changing to manual it goes into manual 5th however, if I then press the UP button it goes into manual 6th, doesn't show O/D in display anywhere.bustupbiker wrote: Wed Sep 26, 2018 11:29 am Also has overdrive sixth gear....but it only works ( it does go into 6th on auto but that 6th is NOT overdrive ) you have to be in Manual mode.
Re: Gearbox on 650
Have changed then, all of my 6 had OD. Then again i sold the last one in 2013
