Xevo
wightegi
Xevo
Post by wightegi »
Hi all a new member here but I know some of you :o I swapped my Suzuki GS500F for an Xevo 250 ie last week it would be nice if I could go for a ride but not for a while . Since I got it I put some air in the tyres they were about 15 psi down each end changed the air filter for a nice red one :roll: and changed the oil for Mobil 1 ,some one had used a 6 foot scafold bar to tighten the sump plug and the plug washer from Wemoto ,about half inch diameter would not fit the 24 mm plug :roll: any way that is all for now and thanks to Capitano for the help ,did I mention I am a Global Mod on the C90Club forum...
StephenC
Current Ride: Kymco DT X360
Re: Xevo
Post by StephenC »
Welcome. Don't forget that with the Quasar engine the clutch housing needs a good clean every now and again or you'll get the dreaded Strangled Sealion (copyright - Mozza, I believe :) )
Can is not the same as Should
Re: Xevo
Not my copyright...
Re: Xevo
Yep wightegi is my good mate from the Isle of Wight.
I used to get the strangled sealion with my old 500 Nexus as I liked and retained the 6 roller variator.
I have a feeling that the term originated from JimC on the old TScoot forum.
8-)
StephenC
Re: Xevo
Post by StephenC »
I'm getting a bit of it with the Forza, probably down to a lot of stop start in the city. Mate who has one was told it was glazing rather than dust but it was still easily cleaned, apparently.
kishan
Re: Xevo
Post by kishan »
welcome :D
Liam
Re: Xevo
Post by Liam »
Welcome Wightegi !
Re: Xevo
Welcome Wightegi, The Xevo was as good as the Piaggio Maxi scooters became, as for any sea lions trapped inside, I have one in my Silverwing from time to time. a few quick accelerations de glazes the clutch drum, it happened on the X9s and Burgman400's
Dave
Honda Wave 110i
