I took the Burger off road today. Nothing extreme you understand, but a couple of miles of uncomfortably bumpy.
Would it have been worthwhile deflating the tyres a little and if so how much? (I have a little 12 volt pump so could have re inflated them easily)
Under pressure..
Red Dog
- Current Ride: Suzuki Burgman 400z
Red Dog
Re: Under pressure..
So I tried it again today with both tyres deflated by about 10psi and it was much better. The only worry was that while re inflating with my 12 volt pump I was scared of flattening the battery because of the need to leave the ignigion and the lights on.
- muddyfox
Leave the engine running whilst pumping tyres up ?Red Dog wrote: Fri Oct 09, 2020 9:25 pm So I tried it again today with both tyres deflated by about 10psi and it was much better. The only worry was that while re inflating with my 12 volt pump I was scared of flattening the battery because of the need to leave the ignigion and the lights on.
Muddyfox (Nottingham)
Ride safe
Ride safe
- Current Ride: Forza 125
Don't rev up the engine when pumping up the rear tyre.
Red Dog
muddyfox wrote: Sat Oct 10, 2020 1:47 pmLeave the engine running whilst pumping tyres up ?Red Dog wrote: Fri Oct 09, 2020 9:25 pm So I tried it again today with both tyres deflated by about 10psi and it was much better. The only worry was that while re inflating with my 12 volt pump I was scared of flattening the battery because of the need to leave the ignigion and the lights on.
Yes, I guess that's the answer.
Red Dog
Ug, that could get messy.
I don't suppose the battery would go flat during the 10 minutes or so it takes to inflate the tyres.
If it does, then it's time to buy a new one!Red Dog wrote: Sat Oct 10, 2020 6:41 pmUg, that could get messy.
