TMAX DX won't start
noeyedeer
Current Ride: TMAX DX
TMAX DX won't start
Post by noeyedeer »
hello
I am fast getting to the point of losing what's left of my hair can anyone help with my tmax dx dilemma?
the key shows its connected,the bike switches on as normal but wont start and the lights screen etc all work but absolutely no attempt to start what so ever!
Fulhamfc
Current Ride: BMW C400 X
Re: TMAX DX won't start
Post by Fulhamfc »
Hi
this maybe in the garage section where you will see my similar problem, see the thread and now mine is playing up again very reluctant to start straight away, fuel battery all good , garage for you methinks
fulhamfc
Fulhamfc
Post by Fulhamfc »
Hi
if it wont turn over at all sidestand switch is a big suspect, wd40 large
ffc
Are you getting brake lights when you pull the levers? Lever Switches OK?
Fulhamfc
Post by Fulhamfc »
wow
never thought will check mine mucking me again
thnx ffc
noeyedeer
Post by noeyedeer »
oops!
yup brake light comes on
all stands up and clear
iam fairly sure it may be somethign to do with the keyless start and tmax connect as feels like it could be electronically disabled but cant find anythign online that helps...
roadster
Post by roadster »
If you rule out a dealer visit then you will have to go back to basics. For example ( assuming the starter is not working ) locate the main starter relay and short it across the heavy duty terminals to see if it turns the engine over and if the engine fires. From there it will be the usual checks, is there a spark?, is fuel being injected?. etc.
Without dealer specific electronic tools you don't have any easy options.
I presume it has one of those switches that cuts of ignition, thats not in the wrong position is it?
hatter
Current Ride: Honda SH 300
Post by hatter »
Make sure you are using the original transponder key with the chip in it.
My spare key turns bike over but will not start it since Honda did an ECU upgrade.
Hatter
EvilRacer329
Current Ride: Yamaha T-Max DX
Post by EvilRacer329 »
I had this exact same issue with my bike just 24 hours after buying it second-hand. I checked every relay and in the end gave up and paid my local dealer to take it in. They were at it for a couple of days before finally finding a slightly nicked wire between the started button and a relay somewhere that must have finally given out - just my bad luck, I guess. My symptoms were identical to yours - the bike would switch on, but pressing the engine start button did nothing.
Nick
