Tricity 300 brake lever adjustment
Tricity300
- Current Ride: Tricity 300
Hi I have a new tricity 300 and would like to adjust the brake levers has anybody attempted this
wightegi
Re: Tricity 300 brake lever adjustment
Find the part number of your lever and see if it is used on any other Yamahas then see if an adjustable lever is available for one of those .
Tricity300
Iām not looking to adjust the lever span but to move the position off the levers but cannot seem to be able to get remove the plastic casings that cover the handlebars I think the Xmax 300 is the same /similar set up
Can the levers be moved on the bars or are they fixed in one position
Scooter
- Current Ride: Yamaha tricity
Try the 2 Allen key bolts underneath assembly.
- Greyerbeard
As Scooter says - you should be able to rotate the whole 'block' that the levers are part of, by loosening the clamping bolts?
1964 Matchless G3
1989 Honda C90
1998 Honda CB250 Nighthawk
2025 Honda ADV 350
1989 Honda C90
2025 Honda ADV 350
