Not starting
Burgman53
Current Ride: An 400
Not starting
Post by Burgman53 »
Hi all, i have a 2001 an400 burgman owned it for about 3 months and its been great, but last week went to start it to return home from work pulled in the brake as normal to start it and nothing after several attempts it started. The next day went to go work and nothing, front and back brake lights work ok and i can hear a click when i check the side stand switch so they all seem ok. Battery is fully charged, but there is nothing from the starter motor no clicking or anything. Any help please.
Current Ride: gb 350s
Re: Not starting
Have you checked the battery connection.
Burgman53
Re: Not starting
Post by Burgman53 »
Hi yes all good, all lights working
Red Dog
Re: Not starting
Post by Red Dog »
Kill switch?
Burgman53
Re: Not starting
Post by Burgman53 »
Its on run. Seems really strange was starting fine
Re: Not starting
Check the starter motor wire connections. These can get corroded over time and you suddenly find the starter cannot draw enough current so it won't turn over. Also work the kill switch several times off and on, off and on. They also can get corroded and prevent engine start up because of inactivity ;) .
Burgman53
Re: Not starting
Post by Burgman53 »
Sorry I should have posted a reply. It was exactly that thanks ๐Ÿ‘
wightegi
Re: Not starting
Post by wightegi »
Burgman53 wrote: Tue Aug 16, 2022 12:30 pm Sorry I should have posted a reply. It was exactly that thanks ๐Ÿ‘
The leads or the switch? could be helpful for others who may come along.
Burgman53
Re: Not starting
Post by Burgman53 »
Was the switch just needed cleaning ๐Ÿ‘
Re: Not starting
That's good it's solved.
