Burgman Front Forks Dismantling Problem
Alexis050891
Current Ride: 1999 Burgman 400
Post by Alexis050891 »
I need to replace the oil seals on the front forks for the MOT, but on one of them the screw in the bottom which is threaded into the metal bit inside is just spinnin, so you can't slacken it or tighten it :evil:.
I've tried everything ranging from counterbores to torx drives to try and hold it from the other end, but they just dont have enough grip.
Has anyone got the proper tool you use to hold it? You can only seem to get them in the US, but I'm not keen on 2-8 week delivery.
Otherwise, advice/banter/slagging off is welcome.
Re: Burgman Front Forks Dismantling Problem
Check on BurgmanUSA site, there's a knowledge base section and I think I remember seeing something about having to hold the inner section in place to release the lower bolt.
Alexis050891
I tried everything I could to try and hold it but I guess there just wasn't the friction.
I got my local garage to do it with an air impact wrench :shock: it worked :o. Didn't think it'd have the inertia.
