Hi everyone. Found this place while looking for a solution to my problem so I hope im OK to post looking for advice staright away. I'm a recent convert to twist and gos.
Recently purchased a Honda SH125 2023 model. After 2000 miles I have started to have starting issues. It initially starts fine, but if I turn it off and try to start again then it turns over once and doesn't start. This is an issue with the idle stop as well. If I leave it a minute or two it starts again with no issues. Any ideas? Battery, spark plug? Fuel filter?
Hello New SH125 owner
juanjo4747
- Current Ride: honda sh125 2023
Re: Hello New SH125 owner
Hi and welcome to the forum
Did it have its first service that includes a spark plug and oil change at some point within the first 1000 miles? Typically this is at the 600 mile point after the engine/piston has bedded in.
Pull the plug check what it looks like and if you have a multimeter check the power in the battery with and with out the engine running.
