no
thanks peeps
Im sad too say it is but sad for orwell motor cycles of Ipswich as it is there problem to fix not mine they sold it to me like it as its leeked from day one but werrenty should take care of that.TmaX9 wrote:There is no oil way or gallery between crankcase halves so it's a straight forward leak caused by internal pressure, unless there is an inherent fault in the casting where someone has been wedging the halves apart with a screwdriver!
Are you sure the dealer properly attempted a repair by splitting the crankcase and re-sealing the joint, or did they just smear some Hermatite over the joint and hope you would go away?
Even if the fault is caused by a blocked breather, the crankcase joint is the last place you want to see a leak coming from as it's a major job to fix. Engine out, barrel off transmission removed....
