Absolutely, prototype racing should be about what is technically possible, not what is technically possible, within the rules...Bluebottle wrote:I think it is, or at least it was in my day:irev wrote: I don't think DCT is outlawed...
"Regulation 2.4.2. Twin clutch transmission systems (DSG) are not permitted."
But as we know, that is the trouble with holding racing up as the pinnacle of what bikes should be.
Gigi Dall'igna will reveal how futile the regulated approach to minimising cost is. The greatest living exponent of `rule compliance, to the very edge of that compliance`.
As for GP rulebook: Throw it out the window, set maximum number of cylinders, available fuel, number of engines for the season, number of wheels and a max permitted weight and a single rider - and let the tech lead the racing. 250 2-strokes with superchargers against 6-stroke rotary engines with electric boost - bring it on!
Never mind reducing costs. It's prototype racing: If you can't afford it, don't come and play, and if you are an inspirational designer, use genius to combat budget. It''s a Samson v. Goliath story, with the added benefit of a free-for-all in leading to benefits that spin off for the roadgoing rider. Start with aerodyanamics and rider ergonomics, as that alone will deliver 25mph+ increased top end.
Simple example: Instead of mandating four strokes and killing the 500cc two-stroke racebike, imagine they had mandated emission controls on those 2-strokes? Aprilia already had the DiTech engine from Orbital, and a 2-stroke is necessarily more efficient in use of primary materials than a four stroke, and both would use similar electronics to control firing and exhausting, so why kill the 2-stroke? In marine engines they reign supreme in efficiency and cost-effectiveness - albeit the size of a house:
What you didn't add to your regulation is the next two sections of banned transmission types
3) Continuously Variable Transmission systems (CVT) are not
permitted.
4) Automatic transmission systems are not permitted. Manual
transmissions with gearshifts assisted by quick-shifter systems are
permitted
Curiously, there's been no objection from any combatant over whether Honda or Yamaha transmission constitute, or could be construed as, dual clutch. One might argue (Gigi, probably) that as the clutches in DCT cannot operate independently, they are in fact a single transmission with a split-mode operation, in the same way that opening and closing the throttle are two separate functions, but sharing a common platform.
But given more than half the worlds total two-wheel production constitutes CVT-equipped scooters, why CVT should be excluded when allegedly `racing improves the breed` is a curious conundrum for the rulemakers to explain...
