Looks cool.Funky I would not worry what other folk think. You will prob make there day and put a few smiles on folks faces
Is it still true Funky that you do not have to tell the DV LA cos it is only a temporary/not permanent sort of thing?? ie; the original colour still exists.
Lyn.
kayz1 wrote:Is it still true Funky that you do not have to tell the DV LA cos it is only a temporary/not permanent sort of thing?? ie; the original colour still exists.
Lyn.
You now MUST fill in the appropriate section on your V5 and send it off to notify them.
As its still yellow on the rear I can get away with it to a degree however I will be sending my completed V5 off before the weekend , the yellow will hopefully have gone in the next couple of weeks if not over the weekend.
I am quite proud of the wheels... must take a photo... the centers are matt black but with gloss red outer.
So that means the Sky tv vans have to do this every 3 months when they change the pictures on the fleet!
Ferret
Current Ride: Aprilia srv 850
Post by Ferret »
Fitted new front brake pads today ,I am trying the ceramic type pads . Went for a ride to bed them in a bit & initial thoughts are very encouraging nice progressive feel without the harsh bite of the Hh rated pads I normally use . Did my usual emergency stop practice once I'd put. Some miles on the pads and work great .
kayz1 wrote:So that means the Sky tv vans have to do this every 3 months when they change the pictures on the fleet!
Maybe not, it might be different with commercial vans... there could be a stipulation that it must state the company name like 'SkyTV' on it or that they can prove is truely is temporary because it changes every three months vs teh average Joe who will get a wrap and stick with it for a couple of years which is more permanent.
bikerdezzie
Current Ride: skyteam dax
Post by bikerdezzie »
Fitted an aftermarket seat from Thailand cheap, going to get more foam added and a custom cover, ordered lots of carbon panels and a new yss piggyback shock also for my msx, big plans for it and its going to look the dogs dinger.
Dezzie
****Maybe not, it might be different with commercial vans... there could be a stipulation that it must state the company name****
Good thinking that man, not thought of that Funky you may well be correct.
Lyn.
Symcity
Post by Symcity »
Oil and filter change
next step
Most of the base black is done except the tank cover, the little triangle on the handle bars and the side panels... and still need to fill in red and white in areas. Overall the combo of matt and gloss is looking good :D
If I have enough gloss red left over I might try wrapping the grab bars... but if that fails or I don't have enough I'll look at getting them powder coated the same red.
