Tmax broken AGAIN!!!!!!!!!!!!!!!
Post by StevenM »
When I fianlly got home my dad took apart the bike to find the secondary pulley is knackered, I need the one of the two pulleys, which from aj sutton is £176, I found one on ebay for £15 so will try this before I spend £176. I can't believe I travelled more than 1200kms before this happened, I was gutted. :( so hopefully an easy fix.
Taipan
Re: Tmax broken AGAIN!!!!!!!!!!!!!!!
Post by Taipan »
How was it knackered?
tarmacburner2
Current Ride: Burgman 400 - Honda Silverwing
Post by tarmacburner2 »
Hello Steve,
Hope the ebay one fixes the problem. Luckily you were on this side of the Channel when it went 'tits up'. As I said at the roadside 'At least it isn't raining'. Has Liam smoked all your baccy yet? :)
Cheers,
tarmacburner2
Post by StevenM »
I hope this makes sense. lol. In the link below I need 20(secondary sliding sheave)+25(spring seat comp). On the 20 it has 4 long holes for the pins so it can open and close, the pin goes up and down but a chunk of each hole has shattered(will add photo at weekend as the bike is in sheffield at my parents house) so the sheave gets jammed. My dad thinks this may be the cause of all the belts i've been going through. Like I said I will add photos when I can.
http://www.yamahascooterspares.co.uk/sp ... CH+2&uID=0
hope you get it sorted soon steve.
mr2tastypieces
Current Ride: Mk1 Tmax
Post by mr2tastypieces »
I had exactly the same problem with mine last year, I fixed it with a used eBay part, hope you can do the same.
Post by StevenM »
Well this is it.
StevenM wrote:Well this is it.
Yer Dad is correct, thats cream crackered alright... :lol:
Hope the cheap e-bay buy does for you..good luck.
Lyn.
Taipan
Post by Taipan »
:shock: That is all! :D
Post by StevenM »
Been to mansfield on the motorway to give it a go and so far so good, thank god
