Being a trusting sort of idiot I ebayed this without seeing it, I know I know.
Seems to have done almost no miles in the last 4 years but has a current mot.
Total miles 24K and from what I can see a sad case of neglect.
Issues that are obvious and I can fix myself:-
Needed over a litre of oil in the crankcase (I thought as much when I saw the dirty state of the filler)
Front pads down to the backing making very nasty noises
Other obvious things:-
Paking brake seized (off)
Baldy rear tyre
Boot lid strut duff
On the positive side it starts and runs, steers and the clutch seems ok. It took very little coolant and doesn't overheat if left to idle.
It's going to have to go into the garage for the rear brakes and tyre, (I'm assuming the wheel has to come off to get the brakes?) so any suggestions of additional work I should ask to be done at the same time would be welcome.
AN400 K2 bit of a heap
Peterp1per
- Current Ride: Burgman 400
davemac
- Current Ride: x9 evo125 + FZR250R 3ln
Re: AN400 K2 bit of a heap
Brake fluid change, general service, maybe a check on the fork seals as well as it hasn't been used in a while.
Check date on the front tyre and if its over 4 years old I'd be inclined to change it as well.
Valve clearences mightn't be a bad idea either.
These are things I would do but I generally do it myself, might be expensive if a garage is doing it.
Sent from my HTC Desire HD A9191 using Tapatalk 2
Peterp1per
Thank you for that Dave, I feel bad not doing it myself, as I could, but I know a good bike mechanic, have a bad back, short sight, and no space to work.
I've arrived at the stage where I just want to ride it and sod the expense.
Unfortunately the wife won't quite sod it with the same enthusiasm, hence the old bike, and then the repairs can get sort of lost in the accounting.
mjf65
- Current Ride: AN400L0
How much did you pay? Im looking at a K1 up for £1100 at the moment
Peterp1per
1100 oddly enough, though in retrospect probably too much bearing in mind I had to throw 480 at it immediately to make it roadworthy.
The rear brake caliper is an expensive repair it seems.
I'm going to take it to the Algarve (shipped, not ridden!) over the winter and it might not be coming back. Scooter repairs are much cheaper there, as there are lots of them and plenty of resourceful mechanics. No mot either which means there are some dreadful old rustbuckets on the roads.
I'm sure you will easily find one to suit your budget and I wish you luck.
- bornagainbiker
You could have invested a little bit more and bought my K8 Burgman 400 with all mechanical service work done also now with recent new front tyre, rollers and belt.
http://www.maxi-muppets.co.uk/forum/vie ... 27#p175827" onclick="window.open(this.href);return false;
http://www.ebay.co.uk/itm/300903118274? ... 1586.l2649" onclick="window.open(this.href);return false;
It's still available if anyone is interested? It's currently not advertised and I'm still using it on a regular basis.
Peterp1per
I know I know, I'm the original one born every minute. In this case although I did look at your bike at the time the distance put me off, I'm in the deep south.
bikerdezzie
- Current Ride: skyteam dax
Al vouch for bornagains burgy, its mint and well looked after, looks new!
Dezzie
- anonstarter
- Current Ride: Pending
That's intrigued me - how much is "a little bit more" Mister Bornagain?bornagainbiker wrote:You could have invested a little bit more and bought my K8 Burgman 400...
- bornagainbiker
I would like £2000.anonstarter wrote:That's intrigued me - how much is "a little bit more" Mister Bornagain?bornagainbiker wrote:You could have invested a little bit more and bought my K8 Burgman 400...
