Removing/tidying scratches
primalcarl
Current Ride: S-Wing
Post by primalcarl »
I've got an area inbetween two panels by my left foot side on my Honda S-Wing that's badly scratched from the previous owner wearing motorcycle boots. It's just the left side and by bad I mean you can feel the scratches easily.
What are my options to make it look better? I could possibly source one replacement panel as its a small one, but there would still be scratches on the adjoining panel which is bigger.
Re: Removing/tidying scratches
Paint it.
You could vinyl that part.
SpikeOne
Current Ride: Kymco Downtown 300i
Post by SpikeOne »
Take it off, rub it down, long with it's matching parts.
Get your local body shop to respray it.
Won't cost much, and job done.
Spike
Kymco Downtown 300i
Yamaha Vity
MZ ETZ251
Honda CD175
Honda CB250 G5
BSA Bantam D14/4
BSA Sunbeam
Honda C50
Vinyl wrap the section on both sides, will only cost you literally a few quid and also stop further scratches. Likely they won't show through
primalcarl
The paint has metallic bits in it so I'm guessing a vinyl wrap would be plain black and noticeably a little different than original?
If the panels aren't too difficult to remove I might go that route with the body shop. It's not a major issue, but enough to annoy me some days!
There are people who do these sort of minor repair/repaint scuffs commercially....they can get remarkably good results, and quite cheap (I believe). Probably best to get an expert to do these cosmetic things than bodge it yourself.
MrGrumpy wrote:There are people who do these sort of minor repair/repaint scuffs commercially....they can get remarkably good results, and quite cheap (I believe). Probably best to get an expert to do these cosmetic things than bodge it yourself.
if you wanted to do yourself, you could mask off a curved area, of the area you have rubbed down, then prime and matt black and lacquervand do same to other side to match, as long as you dont overdo the spray, it will blend in :D
Vinyl wrap comes in all sorts of colors, metalics, pearlescents, etc. you could get a close match or even just change the color.
These areas are prone to rubbing and scratching so even if you do get it resrayed I would get some high micron (100+) clear wrap and cover those sections, it will save it from happening again... whilst your at it covering any areas prone to stone chipping would be good too.
