engine cuts out.
Den1974
Current Ride: Suzuki Bandit_Burgman
engine cuts out.
Post by Den1974 »
Took Burgman 125cc K7 to dealers to get the fault codes(see below)
Problem with it is that the engine cuts out 4 about 1-2 seconds when speed is above 55 ( so high revs)never does it when below 55,and at same time the fuel indicator warning light comes on 4 excatly same length of time engine dies.Once engine starts again the FI warning light goes off,this happens more ofton when fuel is under half a tank.Was told by afew folk thats its most likely the crankshaft sensor,i've stripped down that and visually inspected it and all looks fine.So any ideas?.
FAULTS
P0130 - 02 sensor circut malfunction (bank sensor 1)
P0230 low - Fuel pump circut malfuntion
P0335 - Crankshaft position sensor A circut malfunction
P1650 - Ignition switch signal malfunction
Re: engine cuts out.
Could it be a wiring/connector block fault or a battery on the way out?
bad fuel pump?
Den1974
Post by Den1974 »
Yeah,bike is stripped down,every pannle removed,all connectors and wiring getting checked with multi meter,and yep also thought about fuel pump,that will be getting examined.
