Valves per cylinder: 4
Fuel control: SOHC
Gearbox: Automatic
Torque: 11.70 Nm (1.2 kgf-m or 8.6 ft.lbs) @ 8000 RPM
Top speed: 108.0 km/h (67.1 mph)
Power: 14.50 HP (10.6 kW)) @ 9750 RPM
Displacement: 124.00 ccm (7.57 cubic inches)
Engine details: LEADER engine
Cooling system: Liquid
Lubrication system: Wet sump lubrication
Clutch: Automatic dry centrifuge type
Engine type: Single cylinder, four-stroke
Frame type: Cradled in steel tubes with pressed steel
Transmission type,final drive: Belt
Driveline: Automatic twist and go with C.V.T
Manufacture pictures :
