Hi All,
Hoping to pick all the brains out there clean, regarding the issue of Ignition.
No spark.
From the Haynes Manual, the coil seems ok using a good mutimeter.
Also from the manual, the ICU gives very few of the readings stated, with my meter set to Diode. Assumption, therefore, is that the ICU is Kaput. Anyone got experience in this area? It's an expensive result.
Cheers.
J
400K2 No Spark.
Re: 400K2 No Spark.
Yes, it looks as if it's the icu then. Can't be much else if the spark plug and lead is ok and the battery is fine. And assuming yours is the K2 model as per your title of the thread. Also assuming everything is earthed ok, ie: battery, engine etc etc
